dual exhaust
Old Feb 26, 2003 | 08:10 PM
99huggerorangeZ's Avatar
Question dual exhaust
does flowmaster make a dual cat back exhaust for a 95 V6 3.4
Old Feb 26, 2003 | 11:07 PM
Bliggida's Avatar
The silence is your answer.
Unfortunately they do not. This is do to a clearance issue for the exhaust tubing being run down the driver side. It can be done, but it is extremely cost ineffective, and ground clearance becomes and issue. If you aren't supporting a Force inducted motor or wild N/A build there is really no need to try and run dual exhaust - by that I mean a dual exhaust needed to flow for over 600 HP. Which would require dual 3" pipes.
Old Feb 27, 2003 | 10:53 AM
Question
i know it donesnt have two cats so i can run "true duals" but what i meant just run dual exhaust off one cat with dual pipes
i am running this same setup on my 1991 rs it is a flowmaster american thunder 3" cat back exhaust
Old Feb 27, 2003 | 11:12 AM
JC93Z's Avatar
4" exhaust no cat right here...........
Old Feb 27, 2003 | 11:52 PM
White 97 RS's Avatar
No, I belive you would loose too much back pressure which equals to loss of HP if i'm not mistaken.
Old Feb 28, 2003 | 02:06 AM
bigsteve7's Avatar
http://web.camaross.com/forums/showt...threadid=85388
Look at that thread.
Noct
May 26, 2016 10:26 AM
Firechicken350
Jun 6, 2015 11:25 PM
May 21, 2015 01:04 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
