dyno'd the setup today..
Old Mar 31, 2003 | 12:24 AM
94Camaro's Avatar
well with everything ive done, i jumped at the chance to dyno. granted it was a wideband 02 dyno, it however was setup as an inertia (like a dynojet) and not a load(mustang)...so..i think my numbers work with my old ones. anyway, found out my car is running rich, with a 12.92 A/F ratio at the peaks listed below..
anyway, here goes:
full exhaust w/mufflers, cutout closed:
166.9 hp @ 4800 rpm
203.9 tq @ 4051 rpm (i raised the tq peak.hrm..)
then i asked them to take the cutout off and run it.
cutout open: (using full piping but eliminated muffler)
170 hp @ 4820 rpm
207 tq @ 3529 rpm (got the lower peak rpm back!)
hrm...guess a cutout, no cat, and 3" catbacks do work on 3.4L cars..or maybe its just cause i have higher flowing heads and headers. o well, whatever, im happy with it for now..just gotta throw a cam in there now and see what that does.. and then port/polish the heads, and see how much hp/tq that adds too im hoping by the time im done of having 250 + hp N/A and 260+ tq N/A but well see
edit - o yea, for all you wondering, if you add back the "losses" (supposedly 15% loss) -- that equates to:
(with the cutout open)
200 hp / 244 tq :-D
(but thats estimated at the crank, i couldnt be certain without putting the motor on an engine dyno)
-R
Old Mar 31, 2003 | 01:08 AM
Tiago's Avatar
hell yea
Old Mar 31, 2003 | 10:50 AM
chesee48's Avatar
Not bad at all. I guess the cut-out is proven on all cars, wheather its a v6 or v8. im happy i got one
Old Mar 31, 2003 | 11:22 AM
2turboz28's Avatar
to russell. now for the headwork <coughs>
Old Mar 31, 2003 | 11:38 AM
MustangEater82's Avatar
awesome!
too bad we do no thave that humping smiley
Old Mar 31, 2003 | 04:05 PM
94Camaro's Avatar
heheh
thanks ppl.
something else i just realized...:
while everyone that has been talking to me and looking at this views it as a performance upgrade, keep in mind that everything i have done is STOCK.
engine data for 3.4 hybrid:
bore: 3.623
stroke: 3.31
pistons: cast aluminum pistons for LA1 3.4L("3400") transverse mounted engine
intake: stock 1996 "3100" - cast aluminum, non-ported, non gasket-matched. (considered more restrictive than the 3400 intake)
injectors: 19#/hr GM injectors (stock on the 3100/3400 engines)
basically all i have done is create a very...restrictive 3400 engine (close to the LA1) -- save the roller cam in the transverse engine...
so with that in mind. imagine what i might be able to get if i actually ported/polished the heads, got the 3400 intake (its the higher flowing one), or gasketmatched anything... im sooo looking forward to doing some performance stuff now heheh
ill keep y'all posted :-p
-R
Old Mar 31, 2003 | 04:40 PM
Wolfie's Avatar
Re: heheh
or replaced the 80's "performance" cam
Old Apr 1, 2003 | 04:43 AM
CAJUN-Z's Avatar
From: from the land of Justin Wilson and Huey Long!
A lot of people around my parts are just purchasing v-6 rear wheel drive cars (i.e. mustang and camaro) and replacing the engines with v-8's just to beat the insurance. Engine supports, k member and some suspension stiffining is all that is required...
that would bring up your hp a bit!.....
Old Apr 1, 2003 | 08:44 AM
96fbirdA4's Avatar
Along with cooling system, driveshaft, dash, transmission, harnesses, etc. etc.
Old Apr 1, 2003 | 11:09 AM
94Camaro's Avatar
Yea but I have more pride in my car as a 3.4L V6 than I ever would if it was a V8. Besides, I havent even STARTED to make my car go fast. I mean, I'm not joking when i say all the parts on my engine are STOCK(except for the headers) -- and I have a list of goodies...:
3400 intake, Camshaft (possible hyd/solid roller), ported/polished heads, bigger TB... and maybe some more. (maybe even a little toss of the juice on there too.. but not too much..just some for fun).
anyway, point being that even tho everyone says a v8 is fun, when my 3.4L v6 is runnin 12's it'll be even better
-R
Old Apr 2, 2003 | 03:54 PM
94Camaro's Avatar
im amazed...
looking at the post indicators, 350+ people have checked this post out. didnt realize so many were interested
-R
Old Apr 6, 2003 | 11:02 AM
CANTONRACER's Avatar
Your AFR is fine if it was 12.92 across the board. Not to lean and not rich. I like NA cars to be in that area. Now if you plan on running a SC/Turbo setup, fatten it up big time to be safe then take away.
Not bad #'s at all though. Your making more power than my fiance's 99 V6 5 speed. I dynoed it Friday night and it made 166 rwhp@5200 and 191 rwtq @ 3500.
Old Apr 6, 2003 | 01:44 PM
94Camaro's Avatar
i wish that was so...
wasnt 12.94 across. was 12.94 at peak hp. but when the dyno started it was 11.95, then came up a little to 12.02 and then dipped back down to 11.73 ...
when it hit peak tq it was at 12.72 and then 12.94 at peak hp.
(edit: sorry 12.94 not 12.92).
the guys at the dynoshop told me i was running way rich and that i needed to tune it. of course..i still havent replaced my !Cat (no money rite now to do so.).
so thats probably contributing to it.
-R
Old Apr 6, 2003 | 07:17 PM
94TeALFiReBiRd's Avatar
I have a dyno later this month, i better get my cutout on...
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
