Block off for EGR passage
Old Apr 5, 2003 | 11:10 AM
oil pan 4's Avatar
Question Block off for EGR passage
I was looking at my set of heads and thought it would be a good idea to start off by blocking off the EGR passage before I start porting.
Trying to weld a little peace of steel over it could be realy hard to do plus it would be bad if I arced the valve hole lip or a bit metal spatter stuck to it or the valve guide hole.
I can't use any thing that might chip off, because the only reason I have these heads is to prep a turbo set up over the next 3 years to take back with me.
I can't have bits of hard materal getting blown through the spining turbine.
Any one know of any thing that would cover that passage up and stay in one place?
Old Apr 5, 2003 | 08:36 PM
V6Power's Avatar
Put a freeze plug in the hole.
Old Apr 7, 2003 | 12:17 AM
oil pan 4's Avatar
I should have described it more.
The passage is a smaller square passage in side the head heading tord the intake side.
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Jlo
Jul 29, 2015 03:52 PM
