Engine Swap Help
Old Feb 25, 2003 | 08:11 PM
DTABFORMULA's Avatar
Post Engine Swap Help
hi i have a 96 camaro 3.8 v6 and a 93 formula lt1 the formula is wrecked with lil problems. how hard would it be and what am i going to have to do to put the lt1 where the 3.8 is...please any info will help!!
Old Feb 25, 2003 | 11:40 PM
You are much more likely to find the answer to this in V6 Tech, or LT1 Tech. Moving to V6 Tech....
Old Feb 28, 2003 | 05:47 PM
mustangmuncher's Avatar
Well.. im not sure what much of a difference there is between the 3.4 set-up and the 3.8 set-up but i know all the stuff.. or most of it to do the swap. The 3.4 to LT1:
lt1
ecu w/ wiring harness
torque converter and tranny (4L60-E)
front k member and mounts
springs
shocks
rearend i think
driveshaft
exhaust (manifolds/headers, converter, pipes, mufflers)
radiator
power steering pump
starter
a/c compressor
mounts and brackets
gauge cluster
I think this is most of it.. extremely complicated, but all in all worth it.. in fact im doing it sometime in the near future, give me a private message and i'll send prices and etc if you would like. Its a complete changeover.. and if you have t-tops then you will need subframe connecters and at least possibly a rollbar?. If you were to forego these.. I do believe yours doors will not close correctly and t-tops will get really bad. reminder: rollbar and SFC are primarily going to be needed if your model is a t-top model.. not sure on coupe or convertible.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
