Definitive 2 or 4 bolt main exterior ID?
Old Jan 28, 2003 | 02:20 PM
Timberwolf's Avatar
The block I have says 80-85 2 or 4 bolt mains according to Mortec.com
I have heard the 2 or 3 freeze plug method, but it seems like I also heard that this method is not reliable either. Is there any way to tell for sure?
casting number is 14010207
The engine is assembled for now, and I'd just assume leave it that way until I decide what I want to do with it. Which means not pulling the pan...
Old Jan 28, 2003 | 03:34 PM
Jeff H's Avatar
Is there any engine code on the front pad on the passenger side? That would be the best way to look it up, otherwise you'd need to drop the pan.
Old Jan 28, 2003 | 04:21 PM
1981zzz's Avatar
check the harmonic balancer a 4 bolt main has a big balancer unless some one changed it from a small to a big no matter what 2 or 4 bolt still 350 motor is good Ihave a 4 bolt it has the big balancer try that and good luck
Old Jan 28, 2003 | 07:43 PM
Timberwolf's Avatar
suffix on the pad is FRH
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
