? on tunning Q-jet
Old Feb 26, 2003 | 11:12 AM
bmillington's Avatar
? on tunning Q-jet
I've got a Q-jet on a 350 (78') and I've tryied adjusting it a couple times and rebuilt it, and can't get it to keep from dieing out a couple seconds after starting it. I normaly have to start it two sometime three time when the engine is cold. And it doesn't matter if its 30 or 70 degrees out. Any ideas, could it not be the carb maybe timming a little off.
Thanks for any help,
Old Feb 26, 2003 | 02:09 PM
97z28/m6's Avatar
try adjusting the choke.
Old Feb 26, 2003 | 02:18 PM
I been playing with the fast idle screw. I think to adjust the choke I have to bend the linkage. Should I adjust it to get more air or fuel?
Old Feb 26, 2003 | 03:33 PM
Prospector's Avatar
Along with paying carefull attention to the choke settings, check the choke pull-off diaphram. Seems like nearly every Q-jet I rebuilt had a bad diaphram. This is supposed to pull the choke open a little bit as soon as the engine starts. If it is bad, the choke stays closed and ..um.. chokes the engine!
Old Feb 26, 2003 | 04:59 PM
Mine doesn't have a vacume diafram, it has the older choke with a thermostat bolted to the intake, not a electric choke. Is there a kit to convert it to electric choke?
Old Feb 28, 2003 | 12:48 AM
97z28/m6's Avatar
yes there is a conversion kit but you should be able to adjust the choke by lossening the 3 screws and rotating the housing.
Old Mar 1, 2003 | 07:20 AM
1981zzz's Avatar
I agree with 97z/m6
Old Mar 1, 2003 | 11:25 AM
97z28/m6's Avatar
Originally posted by 1981zzz
I agree with 97z/m6
thats because unlike you i know what i'm talking about.
dfarr67
Apr 10, 2015 07:44 PM
jg95z28
Classic Engine Tech
Mar 20, 2003 06:02 PM
lt1camaroman93
Feb 5, 2003 06:18 AM
bmillington
Classic Engine Tech
Dec 4, 2002 01:37 PM
Mr. Horsepower
Classic Engine Tech
Nov 5, 2002 07:37 PM
