High Beam Headlights for 69 Camaro
Old Dec 30, 2002 | 02:30 PM
kissel's Avatar
One of my high beams is out and just curious if anybody knows if there is a seperate element in the bulb for the high beam. The low beam works fine. The total light was out but I wiggled the connection and got the low to work but the high is out.
Before I go and replace the bulb figured I would ask. It could be that the wiring could be shot. The other side light works fine in the low and the high setting.
My guess is that there is a seperate element.....
any takers
kissel
Old Dec 30, 2002 | 03:58 PM
95droptopZ's Avatar
Smile
Yep! There is 2 elements in the old headlights. Replace it with a new one and while you're at it, wire brush the harness connector. They get a little corroded over time.
Old Dec 31, 2002 | 09:12 AM
kissel's Avatar
thanks. I figured I would ask before I went out and bought the light. Looks like I will replace both of them with a different brand (brighter). Hopefully it solves the problem......
Kissel-
LeftoverChinese
Jan 14, 2024 03:03 PM
Catmaigne
Dec 25, 2014 12:16 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
