need help quick please
Old Mar 2, 2003 | 12:26 PM
k9ulan's Avatar
how do you get the crankshft pulley off.1978 350 .took 3 outer bolts out already..do i need to take the center..(crankshaft bolt)...
Old Mar 2, 2003 | 03:03 PM
97z28/m6's Avatar
i am not sure about the bolt but you will need a puller.
Old Mar 2, 2003 | 06:03 PM
ironjet's Avatar
you only need the puller if you're taking off the balancer , if you get the center bolt off , the pulley should come right off. you'll probly need to use an air gun or a breaker bar to get it off
Old Mar 2, 2003 | 07:21 PM
97z28/m6's Avatar
doh! i was thinking the balancer.
Old Mar 2, 2003 | 11:26 PM
Erik's Avatar
Classic Tech Moderator
you can borrow a puller from Canadian Tire. Ya just need to leave a deposit.
Old Mar 3, 2003 | 03:55 PM
magisnyc's Avatar
If you're only taking off the pulley, remove the 3 bolts & the center bolt. Give it a light tap if it doesn't come right off.
If you're taking off the balancer, you are going to need a puller. Most major auto parts stores let you borrow one for free or a very small fee.
Old Mar 5, 2003 | 12:51 AM
k9ulan's Avatar
thanx guys...
Old Mar 6, 2003 | 09:01 AM
stale's Avatar
Yeah, and if you can't get that center bolt off with a breaker bar due to the crank moving, you might need to get a friend under the car to jam a screwdriver in the flywheel. I had a do that with my '96... damn thing kept moving on me instead of loosening.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
