Q-Jet intake help
Old Mar 13, 2003 | 12:00 PM
jg95z28's Avatar
Question Q-Jet intake help
I was going to go with the Edlebrock Performer because I've had success in the past, but it just dawned on me that the Performer doesn't have a provision for an oil fill tube. I wanted to use my stock Chevrolet-script valve covers, but I'm not prepared to punch a hole in them.
Other than the stock cast-irom GM Q-jet intake, are there any decent alternatives with the the oil fill tube hole?
Old Mar 14, 2003 | 12:45 PM
Damon's Avatar
None that I'm aware of unless you find an old aftermarket intake at a swap meet that happens to take a QJet and has the oil fill tube.
Old Mar 14, 2003 | 10:17 PM
cavemanmoron's Avatar
agreed. swap meet stuff, 1967or so was the last year for that style oil inlet,
i would put on newer style intake,and change the valve covers,or;buy one to add the pcv valve to..
Old Mar 17, 2003 | 12:02 PM
jg95z28's Avatar
What about getting the oil fill hole machined into a new Edlebrock Performer? I can just reuse my 67 oil fill tube which has the provison for the PCV valve.
Old Mar 20, 2003 | 05:58 PM
Damon's Avatar
Should work if you're willing to go that far. Even later blocks still have the little semi-circle in the front block wall that the oli fill tubes used to mate up with.
I'm looking at a picture of an Edlebrock Performer for early style heads (86 or older) and it almost looks like there's a little flat, round spot in front of the water jacket right where the fill tube would normally go, but it isn't machined with the appropriate hole. Might be a simple drilling operation.
Old Mar 20, 2003 | 06:02 PM
jg95z28's Avatar
I'm probably going with the Performer and say screw the stock valve covers.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 26, 2015 08:34 AM
