5.7 vortec in 1981 Camaro?
Old Aug 15, 2004 | 06:31 PM
mfc's Avatar
mfc
I am planning on purchasing a 5.7 vortec supercharged engine and I was wondering if it would fit in my 1981 camaro z28?
Old Aug 15, 2004 | 07:52 PM
Erik's Avatar
Classic Tech Moderator
Re: 5.7 vortec in 1981 Camaro?
Yep, it'll fit. Hood clearance will almost certainly be an issue, so you'll probably need a cowl induction hood.
Old Aug 16, 2004 | 02:55 AM
DWray's Avatar
Which is crappy, because I love the stock hood, but it doesn't give clearance AT ALL. I don't like any other hoods, to be honest.
Old Aug 16, 2004 | 03:10 PM
mfc's Avatar
mfc
So there is no chance of it fitting under my stock hood?
Old Aug 20, 2004 | 06:31 PM
talos's Avatar
not with out a lot of moddifing to the kmember and mounts... who knows ive seen chip foose and troy fit HUGE motors under stock hoods
Old Aug 20, 2004 | 10:55 PM
97WS6SCharged's Avatar
Is this motor a stock vortec truck engine or is it just a 5.7L engine with a Vortech supercharger and a carb bonnet?
Old Aug 23, 2004 | 09:27 AM
Ls1smlblck's Avatar
The carb unit should fit. if not you can cut the hood to fit. I'm running a custom intake set up with a stock type base w/ seal and 3" cleaner. I pulled the scoop off and cut the center out. If you look you have 2 kidney shape slots, I just cut so it's now one big hole instead of the two. I now have clearance and can see the filter coming through hood.
Did you post this on NastyZ?
Old Aug 24, 2004 | 10:45 AM
mfc's Avatar
mfc
Its a vortec engine with a b&m supercharger.
Old Aug 24, 2004 | 11:32 AM
Ls1smlblck's Avatar
A roots type supercharge will not fit the stock hood.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
The Seer
Nov 24, 2014 07:59 AM
67 Camaro
Sep 14, 2002 01:00 PM
