3rd gen steering box in a first gen?
Old May 1, 2004 | 02:52 PM
Freak's Avatar
I read somewhere that you can put a 3rd gen steering box in a first gen to get a quicker ratio.
has anyone done this? it looked like a simple bolt in deal, just wondering if its that easy. I have a leaking box I plan to replace, figured this would be the time to go with a quicker box if its as easy as just getting one for a different year.
Troy
Old May 3, 2004 | 10:06 PM
kacy's Avatar
i am in the process of doing this it is a bolt in item but you have to turn the pitman arm 180* and you either use the ps pump from the 3rd gen or you have to cut and hose clamp your lines
Old May 4, 2004 | 11:47 PM
HouseOfTorque's Avatar
you will not be able to use clamps on a PS pump way too much pressure, even with a flare it is not a great idea...
you can have custom lines made for not that much but you might as well use the thirdgen pump along with it.
Old May 5, 2004 | 07:47 PM
Freak's Avatar
thanks for the info guys
Kacy, what exactly do you mean by flipping the pitman arm 180? is the box shaped differently? do you have a pick of what you have to do?
Old May 6, 2004 | 05:55 PM
kacy's Avatar
the third gen is a front steer set up the gear box is in front of the engine crossmember where as the first gen is behind the cross member making it a rear steer this is why the pitman arm has to be moved 180*
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
19redta96
Jul 23, 2002 12:25 PM
Z284ever
35
Jun 26, 2002 12:20 AM
