Trunk
Old May 18, 2004 | 10:23 PM
jons69's Avatar
Angry Trunk
My trunk leaks water! Everytime I wash my car the trunk will just be standing in water. I have replaced the weatherstripping, that did not fix. Recently had body work done and there was a spot of rust on the corner of the back window, the body shop said that is were the water is coming in. Months after the body work the water is still coming in. I then replaced the gaskets around the taillights and it still leaks. I crawled inside the trunk and had somebody spray it with water it looks like it is coming in from around the corners. I just laid the weatherstripping in there, I didnt glue it down or anything, does it need to be glued down or anything else to work right. Jon
Old May 18, 2004 | 10:43 PM
firstgen's Avatar
Is there a spoiler on the car? if you odds are it's leaking there.
Old May 19, 2004 | 03:12 PM
jg95z28's Avatar
Did you check the window seal? They typically leak there first.
Old May 19, 2004 | 09:23 PM
jons69's Avatar
Spoiler
Before I had the body work done it didn't have a spoiler and it leaked. I had a spoiler added during the body work, and they checked the seal in the window and said it was fine.
Old May 19, 2004 | 09:24 PM
internetautomar's Avatar
If you can, I'd suggest crawling in the trunk again with a light and see where the water is coming from exactly. Is it over the weatherstripping, maybe under it.
Aaront810
Aug 29, 2020 09:34 PM
Bxlt1
Jul 18, 2015 02:48 PM
240ssLs3
Jul 13, 2015 05:06 PM
squarehead
Nov 21, 2014 08:02 PM
