How to find a coolant leak??
I just got my Nova back together and running(seemably strong) but I've got an aweful antifreeze leak somewhere. I'm thinking it's coming form the first water jacket on the passengers' side of the intake for some reason. It's spewing all over the pass. valve cover under WOT. I just changed the intake gaskets again(had a bad oil leak in the back) and don't want to do it again unless I know for sure. I used the right gaskets and plenty of silicone. If I squeeze on the coolant hoses, which are right there in the same viscinity, nothing comes out, but I hate to rule them out. Anyway, it there some kind of trick or tool to tell where exactly it's coming from? I don't seem to have any coolant in the oil either. Thanks for the help.
that tool does infact exist, and I think you can rent them at autozone. but im not totaly sure.
as for how much pressure you have on the system. it cant exceed the pressure of the radiator cap. but that might be stuck closed somehow and be building the pressure way too high. the tool will test that also.
BTW, not sure where you put the silicone, but I havent seen an intake gasket that you should put silicone on. silicone on the end rails is fine, but either leave the intake gasket bare, or use a gasket sealer instead of silicone.
you can borrow the tool for free from autozone:
http://www1.autozone.com/servlet/UiB...ure_tester.jsp
I always put a thin ring of RTV around the water jackets....
Magenta_Hearts
Mar 29, 2017 08:54 PM
