AN Fuel fitting sizes
Old May 18, 2004 | 10:45 PM
Bone Daddy's Avatar
What size -AN fittings/tube do you guys run for the equivalent of 3/8 fuel line?
Old May 19, 2004 | 01:00 AM
SSnthe10s's Avatar
-6
-8 =1 /2'
Old May 19, 2004 | 09:36 AM
Bone Daddy's Avatar
Originally posted by SSnthe10s
-6
-8 =1 /2'
Thanks alot SS
Old Nov 15, 2004 | 01:11 AM
Highlander's Avatar
Re: AN Fuel fitting sizes
its very simple... AN = Army Navy
so... 3/8 = 6/16 which means -6an
1/2 = 8/16 which means -8an .. bla bla bla.
Old Nov 15, 2004 | 10:09 AM
camcojb's Avatar
Only problem being that in the real world the #6 isn't 3/8" i.d., it's closer to 5/16". I use #8 for fuel, it's slightly larger than 3/8" but in my opinion #6 is too small for a performance application.
Try to get a #6 hose pushed over a 3/8" barb some time!!!! Not much fun!
Jody
Old Nov 15, 2004 | 10:42 AM
Highlander's Avatar
Jody
Well Rskrause got over 700rwhp with a -6an line...
Old Nov 15, 2004 | 10:49 AM
camcojb's Avatar
EFI or carbureted? I just wanted to point out that the 1/16th per AN number is not correct. I try to not short-cut the fuel system when building a car. Yes, #6 will work in many cases, but if this was carbed it could be an issue at that power level. EFI doesn't need as large of a feed line but I still use 1/2" hardline or #8, reducing to #6 at the rails if need be.
Jody
Old Nov 15, 2004 | 03:11 PM
Z28SORR's Avatar
The AN dash number multiplied by 1/16 is correct. Except it is for the O.D. not the I.D. So a AN-6 line is the same as a 3/8 O.D. line. For carbs. up to about 900 cfm -6 lines from the fuel pressure regulator to the carb is usually recommended. With -8 to -10 feed line from the tank.
HectorM52
Jul 30, 2017 11:46 AM
ANDYZ28
Dec 29, 2014 09:13 PM
guionM
9
Aug 29, 2002 01:48 PM
Wilson
Jul 21, 2002 04:58 PM
