best aftermarket heads for chevy 302
Is anyone aware of folks using aftermarket heads and seeing big rwhp gains on a chevy 302 MO/DZ motor? We are going to do some more research but my friend wants to bolt on a new set of heads to his 69 DZ 302.
Well in my opinion on of the best head manufacturers on the market is AFR. Brodix also makes a very good quality.
This is not specific info but might get you pointed in the right direction.
http://www.airflowresearch.com/
Http://www.trickflow.com
http://www.brodix.com/
AFR makes a great head but if you want something a little cheaper and 99% as good then I would look at the Pro Topline heads which are available in either cast iron or aluminum. I would stick with something in the 180cc range for a 302.
I have flowed both brands and can tell you that on my bench the AFR numbers were exactly what they advertised and the Pro Topline heads were just a couple cfm lower on the intake but a couple cfm higher on the exhaust if you want to compare. Both brands pretty well spank a comparably sized Brodix or Dart head.
10-31-2016 11:09 AM
95 Mystic TA
07-29-2002 08:50 AM
