dart iron eagle heads 64cc and 200cc intake runner? any good!
Old Jun 26, 2004 | 06:40 PM
ram air camaro's Avatar
what do you guy's think about those heads? i got a budjet so i can't go aluminum
my block is all stock 350 and will be adding a cam with it is it too much of a head ?
my mods are: headers, holly torquer manifold, holly double pumper carb.
56 chevy truck with a ford rear end and a 69 camaro front clip.
Old Jun 26, 2004 | 07:54 PM
BamaZ28's Avatar
too bad I am selling my heads, the guy says he doesn't get paid until next friday though If he doesn't send money by friday, then I will hook you up. I am researching the asme thing right now, which aftermarket head to buy. I want aluminum, but am willing to get iron if performance is good and price. I have been playing with DD2000 and found that AFR 195's are AWESOME, on DD2000 they put 425HP with my combo!!! I know, I know, don't put all your faith in DD2000, but it has to be close. Let me know what you find
Joe
Old Jun 26, 2004 | 07:55 PM
BamaZ28's Avatar
Am I reading that right.....you have a camaro front end on a truck?
Old Jun 26, 2004 | 10:43 PM
oh i meant the front suspension welded on from a camaro.
Old Jun 27, 2004 | 02:13 PM
406TA's Avatar
Trick Flow 23* aluminum heads (195cc) are about the same price as the Dart I/E's but the TFS heads outflow them. For my $$ I'd get Trick Flows any day over the Darts.
Old Jun 27, 2004 | 02:24 PM
your saying that trickflow heads cost around $800.00 shipped! if so dam i will look into it
Old Jun 29, 2004 | 02:08 PM
BamaZ28's Avatar
I have decided to go with the Dart Pro-1 Aluminum 200cc heads w/ 2.02/1.6 valves.
They flow the same as AFR 195's Comp port job which are just under $2,000 a pair. And the Dart's flow that AS-CAST!!!
You can get them from Jegs or Summit for around $1100
Old Jun 29, 2004 | 07:18 PM
BamaZ28's Avatar
I FOUND THE LIGHT!!!!!!!!!!!!!!!
Here ya go, I am getting
BRAND NEW Dart Pro-1 Aluminums 200cc
2.05/1.6
Springs for .550 and below cam
Screw in studs
Straight Plugs
All for $999 shipped.............you can pretty much pick any combo b/w
180cc/200cc/215cc/230cc
2.02 - 2.05 - 2.08 intake
1.6 - 1.65 exhuast
Straight OR Angle plugs
Springs for your cam
Any combo for $999 shipped!!!!
PM me for the info!!!
Old Jun 29, 2004 | 08:51 PM
angel71rs's Avatar
If the Darts flow that much, $999 is a bargain. But that's a big if. Is it independent flow #'s, or #'s from Dart?
Old Jun 29, 2004 | 09:23 PM
BamaZ28's Avatar
I don't know if they are done independently or not. But for the price, even if teh AFR's flow just a bit more or in the same area, these are a good deal
Old Jun 29, 2004 | 10:02 PM
406TA's Avatar
Performance Heads (800) 722-4645 lists the TFS 23* heads for $895 in CHP Magazine w/ free shipping.
Old Jul 5, 2004 | 09:12 AM
HeavyChevySS's Avatar
if you are truely in a "budget situation", use the iron eagles. Get them cleaned up with a nice valve job and maybe some valve clearancing and use undercut race valves. The 350 should be around 375 HP range as long as the compression and cam are matched.
I would get the Pro1s or the AFRs if I was you though.
As you can see in my sig, I have the Pro1s on my 383 and it makes over 450 HP!
Old Jul 5, 2004 | 01:11 PM
i think i'm going to wait untill i save a little more money and then get the aluminum heads. thanks on the reply's i'm tryin to get 400 hp!
Old Jul 5, 2004 | 01:57 PM
Green95Z28's Avatar
good idea with the pro 1s, they are probably one of the best heads you can buy for your money! My buddy has a fully ported set on his nova and runs high 9s with a big squeeze and runs 11.0 on motor with a 406
Old Jul 5, 2004 | 02:39 PM
BamaZ28's Avatar
Here are some heads for ya'
http://www.nastyz28.com/ubb/Forum6/HTML/023923.html
mikey4play
Mar 15, 2015 11:45 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
