what times will I run
Old Sep 14, 2004 | 03:07 PM
balerjoe's Avatar
I own a 69 camaro w/427 .040 over with 236 246 dur@50 .540 .540 lift cam
semi open semi closed heads hooker ceramic headers, 3inch exhaust mighty demon 750 carb weiland single plane intake msd ignition
3000 stall converter, th400 3:55 gears . 10.5 compression. What kind of times can I look to be running
Old Sep 14, 2004 | 09:08 PM
camcojb's Avatar
Re: what times will I run
Mid to upper 12's with traction. Possibly low 12's if you really sort it out.
Jody
Old Sep 16, 2004 | 09:27 PM
novacaine_68's Avatar
It depends on how good those heads are. What are semi-open, semi-closed heads ? Its either one or the other as far as I know, maybe I missunderstood you. If you have aftermarket heads or ported stock heads, and get traction...I'd say high 11's on a great day. low to mid 12's on an average to bad day. Like I said all depends on traction, suspension, and how good that engines breathing.
You could have an 11 sec. engine, but a 13 sec. car, know what I'm sayin' .
Feffman
Oct 9, 2015 05:42 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
