Carburator Help!
Old Jul 12, 2004 | 08:21 PM
pgriffith's Avatar
Carburator Help!
I have a '84 Chev K10 pickup with a 350ci Carburated engine. I dont know didly about carburated engines, this is the first one i have ever had. But its not running right. It will start and idle fine, but when i give it gas it cuts out really bad. If I give it lots of gas it doesnt cut out, its at part throttle or low throttle that it cuts out. I have replaced the fuel filter and all the spark plugs and wires. It doesnt sound like a misfire. Can anyone that knows about carburated engines help me?
Old Jul 13, 2004 | 11:33 AM
1973Camaro's Avatar
What size carburetor you got on there? Is it a new or old carb? If its an old carb the floats could be sticking. IS it a manual or electric choke?
1973Camaro's Avatar
1973Camaro's Avatar
Old Jul 13, 2004 | 11:58 AM
talos's Avatar
hey look u triple dipped
Old Jul 13, 2004 | 08:02 PM
pgriffith's Avatar
Its a 600 CFM an old Rochester i think. It is an electric choke.
Old Jul 13, 2004 | 09:50 PM
1973Camaro's Avatar
Its old ahh ok.
If its an old carburetor could be that the floats are sticking and that would cause it to stall when you applied the gas. Im pretty sure your problem is emanating from your carb. If you got another carb throw it on there and test it out and see if it does the same thing or take the 1 you got off and get it rebuilt or change the floats.
Old Jul 18, 2004 | 05:50 PM
ccrider's Avatar
Re: Carburator Help!
sounds like you're not getting an accelerator pump shot. with the car off and the air cleaner removed , look down the carb and work the linkage . you should see a squirt of gas. the accel pump eliminates the off idle bog you're talking about.
Collinjacobfowl
Jul 30, 2015 09:35 PM
FLIPPINZ28
Apr 5, 2006 11:22 PM
DWray
3rd Gen / L98 Engine Tech
12
Oct 21, 2003 11:00 AM
97ramairtransam
Aug 13, 2003 10:03 PM
cory215
26
Feb 27, 2003 05:47 PM
