which cam for my 350 chevy engine (no emissions)
Old May 27, 2004 | 05:07 PM
ram air camaro's Avatar
Question which cam for my 350 chevy engine (no emissions)
i need some fast advice on ordering my cam for a 56 chevy pickup .
i wan't a nasty cam that will scare people and won't give problem's cruising. i think on a 110 lsa, and i would like to use stock heads.
this truck is a show truck that only sees at the most 100 miles a month!
Old May 27, 2004 | 05:18 PM
BamaZ28's Avatar
I would go for the XE274H or higher XE series, heard they are pretty mean, AND good for the street. I have a XE274H in my 350, but havn't fired it up yet
Old May 27, 2004 | 05:44 PM
that's kind of what i want but the summit tech guy's said i could only go with xe262h, all though i never listen to them.
so the 274H will work great with stock compression out of a 350 gm crate engine.?
Old May 28, 2004 | 09:05 PM
Damon's Avatar
GM crate motors typically have pretty mild compression ratios. Around 9:1, give or take a smidge. Follow Summit's advice on this one. The XE262 is not a grocery getter cam. It's got some bite. Duration is around 218* @ .050. With old style stock heads anything much over 220* @ .050 is giving away more torque than you'll never make up for with increased peak HP. Not a good idea for a street-driven motor with mild gearing and a near-stock stall torque converter.
Old Jun 4, 2004 | 11:42 AM
HeavyChevySS's Avatar
Follow Damon's advise. Do NOT go to big on the cam. You will loose power rather than gain. When I bought my velle 4 years ago it had a stock 350 SBC with a large cam in it and it sounded mean but went no where fast !!!
Good luck with it.
Old Jun 4, 2004 | 01:03 PM
i went with the comp cams XE268H .470 LIFT,
WHAT DO YOU THINK?
Old Jun 4, 2004 | 09:08 PM
BamaZ28's Avatar
here is my SBC with the ZE274H cam
http://www.knology.net/~poison/Vids/Enginestart.MPG
Old Jun 12, 2004 | 04:30 PM
sleepybu's Avatar
WHAT DO YOU THINK?
i've used that cam in a 350, worked and sounded good
Old Jun 21, 2004 | 10:25 PM
UPDATE !!
I SENT IT BACK AND WENT WITH THE CRANE CAM'S ENERGIZER 274h, IT'S ON A 106 LSA, I REALLY LIKE HOW IT SOUND ON BAMAZ28 SOUND CLIP.
DURATION IS AT 118 AND LIFT IS AROUND A .450''
Old Jun 21, 2004 | 11:01 PM
BamaZ28's Avatar
I knew you would like it I actually took those heads off, and are selling them to finance some brand new aftermarket aluminums Let me know how your times are, I have seen people running that cam into the high 12's in 2nd gens
Old Jun 21, 2004 | 11:02 PM
BamaZ28's Avatar
I took my soundclip down, but may repost if anyone requests, or just email it, it is less than 1MB
BTW I have a few more, of some 4K revs, haven't taken her above that yet
Old Jun 21, 2004 | 11:25 PM
cool, send me a sound clip to alfred559@yahoo.com
can you give me more info on the heads your selling and for how much? email me. thanks
Old Jun 22, 2004 | 11:43 PM
BamaZ28's Avatar
http://www.nastyz28.com/ubb/Forum6/HTML/023523.html
Head info, got a buyer right now, I'll let you know if he backs out.
I will email you the sound clip soon
Old Jun 23, 2004 | 02:13 AM
cool, i just bought some iron heads that have 2.02 /1.60 valves, 76cc 882s, is that good compared to the stock gm crate heads? and are rebuilt with a three angle valve job. w
what do you think ? is that cam still ok or should i go bigger than the 274h since those heads will take a .510 lift cam ? any suggestion's would help!
Old Jun 23, 2004 | 02:41 PM
BamaZ28's Avatar
I would stick with the XE274 for now. You can always upgrade. Also, you could use 1.6 instead of 1.5, to get some lift. Make sure you got some flat tops at least with those big combustion chambers. Need to keep the compression 9.2:1 or above for the cam. You will like it don't worry
