How Many Nitrous Guys Are Here?
Old Jun 24, 2004 | 11:00 PM
Nitro Dave's Avatar
Hey guys I have been checking this board out.Im just wondering how many nitrous guys we have here and what type of systems are you running? Dont be Shy,Post up.
Dave
Old Jun 24, 2004 | 11:05 PM
LSUxBlake's Avatar
Nitrous Works GM EFI 150 shot.
Old Jun 24, 2004 | 11:28 PM
96birdlt1's Avatar
NX wet system 150 shot. I am thinking of getting the NOS throttle body though.
Joe
Old Jun 25, 2004 | 05:09 AM
rskrause's Avatar
Moderator
Custom twin nozzle system using NX components, good to 300hp though I never sprayed that much since I also use 20psi of boost!
Rich Krause
Old Jun 25, 2004 | 05:39 AM
Nostang 96z's Avatar
Running NX S.H.O. kit @ 150 hp. This kit is supposed to be good up to 400 hp but I am not going to be the guinae pig to try it out.
Matt
Old Jun 25, 2004 | 07:01 AM
96speed's Avatar
Hybrid system with NX solenoids/nozzle. Haven't sprayed yet.
Looking to start at ~100 and stop at 200 (forged pistons) .
Ryan
Old Jun 25, 2004 | 10:55 AM
LT4383's Avatar
NX Gemini kit 180 shot.
Old Jun 25, 2004 | 10:57 AM
300 dry shot, made out of a lot of parts from my old NOS 5176 kit, and controlled along with the rest ofthe engine by a MoTeC M48Pro ECU. Only sprayed the 300-shot on the dyno. Haven't run more than a 125-shot at the track. Soon
Old Jun 25, 2004 | 01:07 PM
LT4ultraZ's Avatar
twin nozzle NX system set at 100.
Old Jun 25, 2004 | 01:42 PM
speedmiser's Avatar
Until recently, a Dual stage 300 wet shot w/ 2 NX nozzles and a mix of Compucar, NOS, TNT, & Parker parts.
Bought an S-trim not to long ago, so the nitrous is going to be scaled back considerably.
Old Jun 25, 2004 | 05:31 PM
a walker's Avatar
Nitrous Works LT1 wet plate kit. It's jetted for 175 hp, although on the dyno I'm only getting 113 hp at the crank from it
Old Jun 25, 2004 | 06:14 PM
ford's Avatar
I just joined the bandwagon with a NX Gen II kit
probably will run a 125 shot till i can piece together a forged 355
Old Jun 25, 2004 | 06:18 PM
ltwonz's Avatar
nitrous works power wing kit/ 125 shot
Old Jun 25, 2004 | 09:25 PM
darkangel95's Avatar
I am running a TNT F1 kit, but soon plan on going to either a MX MAF dual stage, TNT F2 or a direct port system of some time.
Nice to see you over here Dave, when I order my next Nitrous setup it will be from you. I have heard nothing but good things about your service.
Old Jun 25, 2004 | 09:46 PM
silverz28's Avatar
I'm still doing the install on my NX GM EFI kit.
