Earls Pro-lite 350 and N20 Can you do it?
Old Aug 26, 2004 | 09:57 AM
944v8inDFW's Avatar
I am getting ready to replump my N20 and would like to not use stainless braided if possible. I know the Pro-lite will handle gas ok but wondering about N20? Pro-lite is good to 350 PSI. Comments? Experience?
Old Aug 26, 2004 | 10:45 AM
t-trimz28's Avatar
Re: Earls Pro-lite 350 and N20 Can you do it?
I'm not positive what pro-lite is, but I can can tell you N2O pressure is alot higher than 350 psi. Are you doing a dirrect port system? If so I would imagine that the pressure would be alot lower. Some more details would help.
Old Aug 26, 2004 | 11:15 AM
944v8inDFW's Avatar
Sorry for the lack of info. Using a NX shark nozzel in the intake boot. 150 shot wet kit.
Pro-Lite 350 hose is constructed in the U.S.A. of a tough, abrasion-resistant Nylon sheathing, banded to the textile inner braid embedded in the synthetic rubber liner. This gives the hose incredible flexibility, while maintaining the ability to withstand high vacuum and hot oil temperatures. It can withstand a maximum pressure rating of 350 psi, and an operating temperature range of -40 to +300 degrees F.
Old Aug 26, 2004 | 11:30 AM
DrewHMS97SS's Avatar
i would say no. n2o is running @800-1100 psi depending on the bottle. if you dont want to use the braided lines, bend hard lines with flare sleeves and nuts.
Old Aug 26, 2004 | 01:59 PM
944v8inDFW's Avatar
ok good idea on hard line! what is the prefered hard line material? Stainless or alumimum? (sp)
Old Aug 26, 2004 | 10:53 PM
stainless is pretty. if you want to do a stealthy setup get steel and paint them black.
HAWG
Sep 25, 2015 11:41 AM
maverickmk
Sep 1, 2015 09:17 PM
Cbr02
Aug 24, 2015 07:12 AM
Rittmeister
Aug 7, 2015 01:13 AM
