NX system doesn't work, schematic inside
I tried my system, didn't work. Opened botle, turned on heater, purged, waited till the pressure raised, then turned the arming switch on....nothing. Everything seemed to work when we tested the system. We tested the system with the bottle closed, we reved it to 3000 RPM, and tapped the WOT switch, but got nothing, we thought because at half throttle at 3,000 rpm, there isn't enough fuel pressure and didn't ground the system. So we grounded the FPSS, and it worked. I think the problem lies somewhere in the window switch in my Mallory 685, but I thought I had it hooked up right. PLEASE look at this if you have any idea on whats wrong!
http://www.piranha-fury.com/photopos...schematich.jpg
Re: NX system doesn't work, schematic inside
My question would be where is the FPSS mounted in the fuel system? How far is the fuel solenoid from the rail port? What is the pressure set for? Did you test the system with the vacuum line off the regulator - which simulates WOT?
Everything else is wired correctly. My system is way more complex than yours because I'm using a digital progressive "maximizer", NX TPS switch, and MSD digital spark retard. My system uses 3 relays. My MSD trigger wire needs to be taken FROM ground to retard the timing. It taps into my solenoid positive wire.
I know I've worked closely with both MSD and NX to get mine wired right. Josh Phillips, at NX, is a great person to deal with. His e-mail address is josh@nitrousexpress.com
Frank
Frank
Originally Posted by 12SCNDZ
...Another suggestion is to jet the system for a 50 HP shot, and just wire the FPSS to ground, and see if the system works.
Frank
Frank
EDIT: Do I need to ground the FPSS and then hook the window switch wire before the FPSS? I always thought that the mallory served as a ground, but it doesn't seem to be working.
The problem you are having is due to the drop in pressure in the line between the rail port and the 'noid. When the 'noid opens, you get this drop in pressure, since the pump can't instantly fill that line between the 'noid and the jet.
Move the pressure switch back to the rail port, away from the 'noid.
The further the run from the rail port to the solenoid, the more this will influence it. My first setup had the fuel solenoid mounted behind the driver side headlight, with about 6' of line to the port. With it hooked up as you describe, it did exactly what you said. Once I moved it to the fitting at the rail port, the problem went away.
I don't think it is possible to get it any closer, or to have it go right off the fuel port. There are a lot of people running the same way as I am.
you did ask the question. unless you are running a 3' line it would be worth the try. also that is the craziest way to wire a FPSS ive ever seen. you want your nitrous to cut when pressure drops, not stop the retard.
By the way I have my fpss mounted about 5' away from the fuel port (below the battery tray) and its working properly.
Check the Mallory to see if it gives earth to the voilet wire and choose low rpm settings for testing purpose.
