ignorant on the spray, 'lil help please....
Old Jul 19, 2004 | 11:12 PM
rdhzd1301's Avatar
hey guys...I'm running the mods listed below with the NOS 5176 kit...where should i mount the nozzle, since this is a dry shot do i have to mount before the MAF so that the ECM knows to add the xtra fuel? also since there is no fuel solenoid how does the motor know to add the extra fuel? I just want to make sure that I have everything right before i go poppin' the pill and blow my sh*t sky high...all help appreciated thanks 'yall
Old Jul 20, 2004 | 12:45 AM
disco192's Avatar
Re: ignorant on the spray, 'lil help please....
before the MAF. Dont shoot until at least 3500 rpm. Have fun man.
Old Jul 20, 2004 | 07:27 PM
rdhzd1301's Avatar
there is nothing else that i need to do with this kit?
Old Jul 20, 2004 | 08:56 PM
rdhzd1301's Avatar
i just thought of something else...won't the spray freeze the MAF???
Old Jul 21, 2004 | 09:42 AM
COMNBYU's Avatar
One of the joys of having a DRY shot Why didn't you go with a WET kit? A lot simpler/safer.
I have run a dry shot on one car ('04 Altima in sig), although not a LT1. I mounted the nozzle after the MAF just before the TB. The theory behind mounting it BEFORE the MAF is that the computor will automatically add fuel, but I have heard of people freezing/messing up their MAFs doing this (I didn't say ALL people). Either place you mount it (before or after), the computor should pick up the fact that more air is being added, and thus should richen things up abit. BUT, just keep in mind that you're relying on the computor to add extra fuel, and relying on your stock injectors to handle that extra fuel (if you haven't replaced them).
On my LT1 (the '96 Z in sig) I ran a 150 WET shot on a basically sotck motor, for a little over a year and a half with no problems. With a WET kit YOU add the extra fuel and you know it's getting it.
Good Luck, Jon
Old Jul 21, 2004 | 12:04 PM
JucinGTA's Avatar
If its a dry kit there should be a regulator that comes inbetween the solinoids. You run a vaccum hose to the port on the fuel pressure regulator. Thats how it gets its fuel by bumping up the pressure.
Old Jul 21, 2004 | 05:01 PM
mrr23's Avatar
the 05176 kit for the lt1 puts the nozzle AFTER the MAF. i had one on my 94 Z28 years ago. it should have 2 n2o solenoids. you put a "T" between them and run a vacuum line to the regulator. it also comes with an inline fuel pump. the kit is rated at 125hp. stock my car went 13.60. on the bottle it went 12.24 @ 113.90. this was an auto with 2.73 gears to boot.
Old Jul 21, 2004 | 08:51 PM
rdhzd1301's Avatar
i appreciate the help guys...just one more question...where exactly do i hook the vacume line up to the FPR??
Old Jul 21, 2004 | 09:54 PM
MetallicTrans96's Avatar
Whys that?
Old Jul 22, 2004 | 04:50 PM
mrr23's Avatar
what you will do is run a vacuum line to the FPR located at the back of the manifold. then you'll make a "T" connection there also. that way you can hook the fatory vacuum line to one side, the line from the "T" at the solenoid on another side, then line from the "T" to the FPR.
do you have the instructions? you can call them and get one.
Old Jul 22, 2004 | 08:37 PM
AZ2ENVY's Avatar
DO NOT put the nozzle before the MAF . You will blow the MAF
clear to hell . Put it AFTER the MAF sensor . Good luck and happy
spraying
Old Jul 22, 2004 | 09:42 PM
rdhzd1301's Avatar
I really appreiciate the help fellas..it's nice to know you can get good tech info for free, from guys you've never met in person before....
yeah i have the directions but they are so dang vauge....i just wanted to clear them up a 'lil
Jeff1904
Jun 5, 2016 05:00 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
