How much should I spray?
Old Aug 17, 2004 | 02:31 PM
30thCamaroZ's Avatar
I just put together a 355 LT1 to go into my 89 RS. I used some Speed Pro Forged pistons and Eagle H beam rods with the stock crank. With stock ported heads and a good cam combo I'm hoping to be around 400rwhp on motor and was thinking of spraying a 150 shot on top of this. You think I'll be safe? I'll do the usuals as far us upgrading the intank pump and so forth. I'm not a newbie to nitrous just wondering what this motor can handle.
Old Aug 18, 2004 | 12:00 AM
Darrells93TA's Avatar
Re: How much should I spray?
i have used up to a 175 shot at times, and it will be seeing 200 maybe more in the near future with my LT1 that has been together for nearly 5 years. stock crank, 6' eagle "SIR" rods, and Keith Black hyperutectic pistons.
just make sure you use all the usual nitrous precautions (timing retard, octane, cold plugs, ect... ) and im sure you'll be fine with a 150.
Old Aug 18, 2004 | 09:03 AM
Will84's Avatar
There are guys running a 150 shot on stock internals... so I think you'll be fine. That stock crank should be good up to 700hp.
Old Aug 19, 2004 | 06:52 AM
N20Dave's Avatar
There is a misconception about "how much" nitrous a motor can handle. I've seen stock 2 bolt cast crank cast piston motors handle 200+ for dozens of runs without so much as a whimper. The tune is key. With your combo, assuming it's put together right and the nitrous is tuned right, I wouldn't be afraid to hit it with 250 but 150 is a good starting point to sort things out.
Old Aug 22, 2004 | 01:52 AM
TransAm396's Avatar
the tuning part is right..and i have proof of that...i took every possible precaution in my 93 with over 115 EXTREMELY hard driven miles..and it saw about a bottle a week..sometimes more..one time..i used it 11 times in an hours time...i raced 11 people(it was a 100 shot) i have mt streets so i juiced from 1st to 6000 rpms in 4th...car never had a problem till the clutch went..lol then i sold the nitrous. im doing a forged/billet bottom end over the winter and ill be goin a two stage(2 separate nitrous kits) and have the first kit spray 150shot from 3500-4500 and the second 150 shot kick in from 4500-6500(300 total)..boy am i gonna have fun.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
