will an fittings hold nitrous pressure levels?
Old Aug 13, 2004 | 01:10 AM
jasonisdn's Avatar
Question will an fittings hold nitrous pressure levels?
i was told AN fittings can withstand nitrous pressures and then of course someone else said "no they can't" . so what i need to know is will i be able to cut my feed line, under my arm rest, and add a small pressure gauge in my ashtray with a tee fitting and short piece of hose??
Old Aug 13, 2004 | 09:34 AM
383Z4ME's Avatar
Re: will an fittings hold nitrous pressure levels?
Nitrous kits from NOS come with AN fittings. I would bet they are fine.
Old Aug 14, 2004 | 01:30 AM
97WS6SCharged's Avatar
I thought NHRA made it illegal to run nitrous or fuel lines into the cabin of the vehicle?
Old Aug 14, 2004 | 11:08 AM
96speed's Avatar
There are not many options for Fbodies regarding nitrous bottle location options .
Ryan
Old Aug 14, 2004 | 12:57 PM
jasonisdn's Avatar
nhra doesnt have anything to do with me
Old Aug 15, 2004 | 10:12 AM
Serene's Avatar
just fuel lines are illegal inside. nitrous is fine
Old Aug 15, 2004 | 01:51 PM
LPEdave's Avatar
Originally Posted by jasonisdn
...will i be able to cut my feed line, under my arm rest, and add a small pressure gauge in my ashtray with a tee fitting and short piece of hose??
Yes, you will. Assuming the fittings don't leak, they are completely capable of holding the pressure.
Dave
Old Aug 15, 2004 | 06:28 PM
jasonisdn's Avatar
Dave
thanks guys guess its time to call jegs and get the junk shipped
Old Aug 15, 2004 | 11:54 PM
Cutting braided SS line, and installing the AN fittings correctly is not the easiest thing to do.
An alternative is to get a "gauge block" (Earls and NOS make them), insert it between the end of you main hose and the solenoid, and use the 1/8" NPT side out to insert a 1/8" male x -3AN (or whatever size the connection is on your gauge) male fitting (its actually a special fitting, for nitrous gauges located inside the passenger compartment. It has a very small restriction orifice in it, to prevent a large flow of nitrous into the passenger compartment if the gauge breaks - AutoMeter includes these with their mechanical gauges), and run a -3AN hose to your pressure gauge.
Old Aug 16, 2004 | 12:12 AM
jasonisdn's Avatar
nice idea, easier than mine. thanks
Old Aug 17, 2004 | 12:52 AM
JWINN's Avatar
The AN fittings would be the least of my worries considering that is what is used on all nitrous kits when connecting line for nitrous. I would be more concerned about the line bursting if by chance your using anything out side of teflon line. Don't forget a nitrous line will see psi from 0 to as much as 1200psi plus depending on bottle temp.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Feb 17, 2015 10:51 AM
bandit383lt4
Dec 21, 2014 09:12 PM
