How much nitrous can she handle?
Old Sep 2, 2004 | 09:16 AM
TQdrivenws6's Avatar
I know, there is no set numbers, but I am just curious.
The motor has the following:
Eagle forged 3.75 crank
Eagle forged H-beam rods with L19 rod bolts
Forged JE/SRP -16cc dish pistons
Pro-Gram 4 bolt splayed caps with ARP studs
Clevite 77H bearings
JE ring kit
Compression is roughly 11.4:1
Cam is GM 847ish, but more aggressive ramps.
What would be feasible both on 93 and race gas?
Thanks,
Chris
Old Sep 2, 2004 | 04:02 PM
94Z28rag's Avatar
Re: How much nitrous can she handle?
A LOT!
You've got the basics down, you could easily do a 200+ shot without worrying on race gas.
Old Sep 2, 2004 | 05:01 PM
Heh, I like that answer!
I am thinking that it might be nice to go with a wet kit and just have a fuel cell with race gas in it for the nitrous, is that a reasonable idea? I am not sure if wet kits are considered safe or reliable at that level, so if anyone has good links on stuff like that let me know.
Thanks,
Chris
Old Sep 2, 2004 | 05:27 PM
94Z28rag's Avatar
Wet is safer compared to dry, but more expensive. You'll just have to do all of the regular safety stuff like fuel pump, colder plugs, retard timing, etc.
Might wanna look into direct port if you want to spray big.
Old Sep 2, 2004 | 06:03 PM
The main problem with direct port is that its not easy to tune. I also want to keep it very stealthy, so direct port would have to go under the manifold. I wouldn't have a problem plumbing it, but the continual removal and installation would cost a fortune in gaskets alone!
Old Sep 3, 2004 | 10:09 AM
94Z28rag's Avatar
Just jet it big and never look back!
Old Sep 3, 2004 | 10:45 AM
Its easy to say that when its not your motor
Old Sep 3, 2004 | 11:08 AM
94Z28rag's Avatar
Fair enough.
Old Sep 3, 2004 | 01:00 PM
Nitro Dave's Avatar
The srp piston is a street version of the JE pistons.I beleave they are rated up to a 250 shot.I could be wrong but im pretty sure.
Dave
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
95blkss
Sep 22, 2015 03:18 PM
tommalcolm
Sep 11, 2015 03:39 PM
