Msd 6al
Old Aug 20, 2004 | 10:54 AM
Gripenfelter's Avatar
Msd 6al
Will any MSD 6AL work with an LT1?
One of my friends just won one off ebay but the seller was using it on a Datsun.
Is this the MSD unit that will allow you to retard timing yourself?
1 degree or 2 degrees for 100 shot?
Old Aug 20, 2004 | 11:53 AM
Gos2Slo's Avatar
Re: Msd 6al
Yes, any 6AL will work. One poar of little wires on the side will need to be reconnected though, but it's not a big deal. No, it will not retard timing, only the Digital 6+ or Digital 7 will retard your timing. Use a MSD timing retard to do this. The rule of thumb is 2* per 50 shot, so at 100 you would theoretically pull 4* to be safe.
Hope that helps,
Chris
Old Aug 20, 2004 | 12:29 PM
Re: Msd 6al
Hope that helps,
Chris
So he should buy an MSD digital 6 instead? Or is the MSD timing retard something you can buy seperate? He has an Accell 300+ ignition system right now.
Old Aug 20, 2004 | 12:54 PM
Gos2Slo's Avatar
Re: Msd 6al
I would get the Digi6, good box. The Timing retard is a separate box you can buy, but I would sell the Acell system and get the Digi6, nothing else to buy that way.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
