Wet kit on an LT1
Old Jul 15, 2004 | 10:26 PM
95WhiteTA's Avatar
Wet kit on an LT1
How hard is it to install a wet nitrous kit on an LT1? And is the wet kit really alot better than a dry kit?
Old Jul 16, 2004 | 10:11 AM
COMNBYU's Avatar
If you're mechanically inclined, it's pretty easy. Heck even if you're not, it's fairly simple to do, and the kits come with instructions. It's just time consuming, that's all. Take your time and it'll be fine. I did my first kit in about 3-4 hrs.
And yes, a WET kit is much more efficient, thus "better" IMO. Everyone here will give you there own opinions, but keep in mind one thing-
-With a WET kit you're physically adding extra fuel with the nitrous going into the motor.
-With a DRY kit, you are NOT ADDING any extra fuel with the nitrous. You are relying on the injectors/computor to add more fuel.
That's the main reason I don't like DRY kits. That doesn't mean they don't work, hell I used a DRY kit on my Altima and it worked like a champ. IMO though, a WET kit is more efficient and "safer".
Jon
Old Jul 18, 2004 | 03:13 AM
jeremyferguson's Avatar
I agree that wet kits are safer, thus better......I finally put mine in after a year of it sitting in my basement. Went from 50hp during testing to 100hp on a bolt-on lt1 with long tubes and true duals. Next comes a walbro fuel pump, afp regulator, and a 150hp shot to see how she likes it.
Old Jul 18, 2004 | 06:59 AM
95WhiteTA's Avatar
Yeah i'd much rather go with a wet kit then blow my motor with a dry, lol, but i wouldn't do more than 100 shot cause my TA is mostly stock with minor bolt ons.
Old Jul 24, 2004 | 01:05 AM
craigffb's Avatar
Re: Wet kit on an LT1
Follow the link at the bottom to my web page for a how to.
Old Jul 24, 2004 | 12:51 PM
SDAKOVIC's Avatar
wet kit here.easy and reliable.
Old Jul 24, 2004 | 11:59 PM
Somnambulist's Avatar
you need to raise your fuel pressure if you use a dry kit or even go with bigger injectors in order to compensate...
Old Jul 26, 2004 | 08:19 PM
MetallicTrans96's Avatar
Wet kit. I have the Nitrous Works Plate system.Easy to install and change jets and i know i'm getting my fuel to it
Old Jul 29, 2004 | 10:20 AM
Nitrous Crazed's Avatar
You cant beat a wet system.
Old Jul 29, 2004 | 10:30 AM
ford's Avatar
Actually you can, i threw my bottle on the ground and kicked my solenoids at my dog. So yes, you can beat a wet kit
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
