will my stock bottom end handle a 200 shot?
Old Jul 21, 2004 | 05:00 PM
F(ast)-body's Avatar
I know LT1's are tough but will my heads/cam LT1 take a 200 shot repeatedly or should I just do 150?
Old Jul 21, 2004 | 07:29 PM
Loadre's Avatar
Re: will my stock bottom end handle a 200 shot?
It will take it, but not for long.
Old Jul 21, 2004 | 09:05 PM
slomarao's Avatar
With a heads and cam car I would be careful on a 150. The 200, no, gonna throw a rod or something.
Old Jul 21, 2004 | 09:36 PM
Jim_H's Avatar
Actually, it will depend on the tune. Run it safe with plenty of fuel, an upgraded ignition and it will last. You will be pushing alot of horsepower through a stock bottom end though.
Old Jul 23, 2004 | 02:14 PM
sniffin94's Avatar
Mine has for 8 months now, I just watch the a/f gauge. I don't have heads cam though.
Old Jul 23, 2004 | 03:28 PM
chevyguy3's Avatar
i sprayed 200hp on a stock 80k mile shortblock, heads, cam combo for a whole year with no problem. i made over 250 track passes that year (not all nitrous passes), and a ton more passes on the street. compression was ~11.2. just keep it from detonating and youll be fine. also keep in mind a 93-94 shortblock will throw a rod much easier than a 95-97 with powdered metal rods. i went 11.34@121 on motor, and 10.54 @ 132 on the bottle in daily driver trim (was the only car i owned). also its very important not to spray that amount for much longer than a normal 1/4 pass would take, or to spray it several times right after another on the street. the stock LT1 ring gap isnt large enough to allow for that much heat buildup, and the ring ends will butt together and break the ring lands on the piston. normal dragstrip passes with at least a few minutes to cool down in between runs will work just fine
Old Jul 23, 2004 | 06:34 PM
T/A lt1's Avatar
WHAT KIND OF CAM AND WEIGHT WERE YOU RUNNING TO GO 11.30'S n/a? Also what kind of LSA did the cam have? Later Clint
Old Jul 23, 2004 | 07:37 PM
chevyguy3's Avatar
cam was a cc306 (230/244 @ .050, .544/.576", 112LSA hydraulic), raceweight was 3600lbs. stock shocks, tranny mounted torque arm, etc. was a 95 firebird with a 6 speed
D1SC383LT4
Jan 1, 2016 01:56 PM
Killer94z
Jan 13, 2015 12:06 PM
97 RedSS
Jun 10, 2003 07:58 PM
