What plugs to use?
Re: What plugs to use?
Hello first timer, to help you alone with this topic just do a search on plugs and you will see many topics about which brand to use. It will show the pro and con's to help you decide which plug will work for you.
definately do not shoot the gas to the platinum plugs
bad idea because it will take the small part of the electrode right off of it.
NGK TR6s are good plugs for street use and n2o use if you are keeping a small shot
if you use a bigger shot then you need to look at the heat ranges of different plugs to determine what you need to use
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
