Dynoed with NX
Old Jul 31, 2004 | 11:34 AM
silverz28's Avatar
Dynoed with NX
Disappointed in my dyno. Last time I dynoed was before my Lloyd Elliot heads and it was 300rwhp. This time with the heads it was 291. But, I bumped up the fuel pressure because of the NX system and I was running real rich. 11.8 fuel ration. They hooked up a meter during the dyno. Ok, with a 75 shot, I did 341 rwhp and 357.7 rwt and 11.2 fuel ratio. And without changing the fuel jet and just putting the 100hp nitrous pill, I got 372.6 rwhp and 416.3 rwt with 11.7 fuel ratio. I think a little rich. And I do have a 2800 stall converter which robs some HP on the dyno. Oh, well. Then on the way home, I was gettin' on it pretty heavy without nitrous and it spewing oil from the passengers side valve cover. Maybe the oil fill tube.
Old Aug 1, 2004 | 09:07 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: Dynoed with NX
ruh roh, the oil spew is a syptom of a broken ring land !
those power numbers are pretty low :-/ (na)
Old Aug 1, 2004 | 10:39 PM
Wild1's Avatar
Re: Dynoed with NX
I wouldn't think the ring land would go with such a low shot... but the symptoms are right.
Do you have access to a leak down tester?
Old Aug 2, 2004 | 04:41 PM
4SFEDZ's Avatar
Re: Dynoed with NX
hey silverz28 where are you located in tx
Old Aug 2, 2004 | 08:43 PM
silverz28's Avatar
Re: Dynoed with NX
Yes I was thinking the same thing. Oh well. I havn't even used the nitrous but two times on the street with a 75 shot and the dyno. It was leaking oil from before anyway, just not spwewing like now. Time to rebuild I guess.
Old Aug 8, 2004 | 02:35 PM
ZDriver96's Avatar
Re: Dynoed with NX
i blew a piston ring.. spewed oil up the pvc pipe and back into my throttle body.... smoked a lot too..Your numbers were low cuz u were running on 7 pistons.. Do a compression test on your pistons.
Old Aug 12, 2004 | 02:17 PM
HeavyChevySS's Avatar
Re: Dynoed with NX
damn that dont sound good. I hope you didn't break anything.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
