Mallory modes.
Old Aug 17, 2004 | 04:37 PM
94NDTA's Avatar
Mallory modes.
What should I set all my modes at on my mallory 685? I have an NX nitrouse kit.
Mode 1: what do I set it at? My engine is internally stock
Mode 2:...I don't think I need to set this
Mode 3: 2 degrees per 50 hp shot right?
Mode 4: I don't know what the start retard value is.
Mode 5 and 6: 3000-5600 right?
Mode 7: don't need this
Mode 8: don'y need this
Mode 9: set at 8 cyl.
Mode A: don't need this.
Old Aug 18, 2004 | 01:56 PM
sssalah's Avatar
Re: Mallory modes.
Set mode 1 (main rev limiter) to 100 rpm lower than the pcm controlled limit, this is to avoid lean condition at the top end with n2o.
Set mode 4 (start retard) to the minimum, the pcm will do it for you, this is usefull on older cars.
You are fine with the rest of them.
Old Aug 18, 2004 | 07:43 PM
94NDTA's Avatar
Arrow Re: Mallory modes.
The stock rev limiter is 5800, right? so set it at 5700.
n2oblkz
Oct 22, 2015 02:31 PM
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
81formula'bird
Pacific
Mar 13, 2003 04:49 AM
81formula'bird
Classic Engine Tech
Mar 12, 2003 06:29 PM
