Nitrous line routing question
I have the NX kit and ran the line through the passenger side under the carpet and now need to get through the fire wall. People tell me there is a gromet behind the computer and I can see it from the engine bay, but not from inside the car. Any suggestions on where else I can run it, or anyone have a suggestion on how I feed the line through the gromet?
Well it does come through
just up pretty high behind the glove box. Probably if you stuck a screwdriver through from the engine bay side, you could feel around for it up behihd the glove box. Or you could drill another hole in a more convenient place. Either way, make sure there's a grommet around the braided line, you don't want to cut through the wires that go through there, or cut the braided line against the firewall.
Dave
just up pretty high behind the glove box. Probably if you stuck a screwdriver through from the engine bay side, you could feel around for it up behihd the glove box. Or you could drill another hole in a more convenient place. Either way, make sure there's a grommet around the braided line, you don't want to cut through the wires that go through there, or cut the braided line against the firewall.Dave
Originally posted by Injuneer
As I recall, you need to pull the passenger side foot well side kick panel off to access the PCM grommet from inside the car.
Speeds8erM-1
Jul 18, 2002 11:36 PM
