Want to forge a 355...200 shot?
Old Jul 20, 2004 | 04:08 AM
96LT1TX's Avatar
What internals would work best on a 355 or a 383 if I were to get a new crank, connecting rods, dished pistons, and a much lower compression?
I have been told of the Eagle 383 blower setup 5.70" H-Beam rods, 3.75" Forged crank, 4.030" Bore SRP -31cc dish pistons and it makes 9.0:1 compression w/ 58cc heads.
1750$ though is kinda steep, I thought you could go cheaper?
What is wrong w/ the scat9000 230$ crank? would that be good for a nitrous app? any advice is appreciated,
thanks
Old Jul 20, 2004 | 11:03 AM
12Second3rdgen's Avatar
Re: Want to forge a 355...200 shot?
No point in lowering the compression, not as big a deal in nitrous setups, it will just cost you HP all around.
I would go with a set of SRP pistons ($430 off ebay), a set of Eagle H Beam rods ($320 off ebay) and a 5140 forged crankshaft ($400 off ebay).
You could probably get away with the Scat 9000 crankshaft. I have a friend spraying 175 horsepower with TRW pistons, stock rods with good bolts and a cast crank.
Old Jul 20, 2004 | 12:16 PM
LT1Squirrel's Avatar
nitrous loves compression
Old Jul 21, 2004 | 06:43 AM
TransAm396's Avatar
hey im kinda in the same boat....i wanna do a 355 street sleeper with a 200 shot..what kinda compression should i be lookin for? and would a forged bottom end hold everything? It would mostly be a 175 shot unless i go to the track..but i wanna make sure with 175 i wouldnt have to worry about **** breaking..or being careful on using it..i used a 125 shot on my stock LT1..went through about 9 bottles in 2 months never a problem
Old Jul 22, 2004 | 06:52 PM
slomarao's Avatar
The compression could be anywhere between 10-1 to 13.5-1. Depending on how you build the motor.
The bottom end, I would get all forged internals. When your building the motor there isn't any point to save a few hundred bucks to have a weak point in your engine. You mentioned a 355, a 383 isn't too much more. Just the machining for the bigger crank. Then you would have plenty of room to grow too. You would also have to upgrade other parts of the car. You can't expect a car that was designed to handle 275hp hold 400+.
Old Jul 26, 2004 | 10:26 PM
96LT1TX's Avatar
my car is definitly not stock any more... how much machine work is needed for the 383?
check sig for mods, I would need fuel and a rear end... but just want a 200 shot
Old Jul 27, 2004 | 09:30 AM
ford's Avatar
Why stop at 200? if im spending money on the engine it damn well better handle 250+
Old Jul 29, 2004 | 11:36 AM
Hot Rod Hawk's Avatar
You said that right, with 13.3:1 on a 200 it went 10.41
I just bumped it up too 13.7:1 on the little 355 on stock heads that could
C-16 and 22 degrees of timing baby.
Old Jul 29, 2004 | 11:40 AM
TransAm396's Avatar
yeah thats pretty damn fast..im lookin for 11.99..thats all i care about..anything after that is an added bonus..but the 200 should get me there on the right engine.now..i just need to start looking for internals..wheres a good place to look?
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
