zex kit
Old Aug 6, 2004 | 07:36 PM
RichyZ28's Avatar
zex kit
hey guys im just about done installing my zex kit but the throttle position sensor (white wire) where exactly do i wanna hook this to? i cant find the wire im supposed to splice it into. can anyone kinda give me an idea where exactly it is and what color the wire im supposed to splice it into is? i think its red but i just wanna make sure i got the right one.
its a 97 z28
Old Aug 7, 2004 | 12:06 PM
jasonisdn's Avatar
Re: zex kit
on my 96 it was the grenn wire. i had a black/green and another dark color. leave the bottle unhooked (if it's filled) and turn the switch to the run position then arm the system and turn the throttle wide open and you will hear the box activate. if not wrong wire on tps. if you have a test meter just find the wire with 4.25 volts at wide open throttle (with the engine off just in the run postion )
Old Aug 7, 2004 | 03:53 PM
RichyZ28's Avatar
Re: zex kit
cool thanks
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
