View Full Version : N2O Tech
- Can you leave the bottle open?
- solenoid brackets
- car goes duh on the hit
- nitrous purge
- How much on an L98?
- Spray through the shifts???
- NX Direct Port Fuel Rails?
- how much power did i lose???
- Low Pressure DP Fuel System
- accel retard box
- How big can I go?
- Nitrous destroyed my cat?
- safe shot on a 3.4??
- N20 hasnt been used in over 2yrs...
- ? for you wet plate guys
- MSD Dig 6 or Window Switch??
- How would nitrous be on my motor...?
- Mounting Nitrous Jet on LT1 Dry Kit
- What do i need?
- Help from people with TNT bottle warmer
- pulling timming
- tnt F1 vs. F2 for LT1's
- What Type Of Spark Plugs To Use?
- What are all the safety switch i need?
- Propane and N20 Injection?
- Please tell me why I can't run stock plugs with N2O??
- umm i realy need to kno some stuff about N2O
- Need pics of solenoids mounted on a BMR STB please
- Where to buy NX solenoid brackets?
- N20 Safe for my Internals?
- Going to get a nitrous set up this summer
- Need the safe way to spray.
- Tapping the TB
- Which kit do you prefer?
- What kind of fuel pressure regulator you all using with dry kit?
- N20 On Stock Bottom ???
- Opinions: how long will it last?
- Running Mid 10s with a 383 and spray?
- diff between N2O and Fuel solenoids??
- Wich head gaskets for N2O ?
- Pics of damage, nitrous caused..
- How much is too much
- New to NO2
- Advice needed, mounting bottle opener after thermostat!
- Time to set the record....250+ through a stock shortblock
- TNT Install ?
- All NOS bottle opener users inside...
- Please help me pick a cam...
- Which wire is for the tach?
- Question about Nitrous Works Nozzle
- progressive set-ups
- Has anybody sprayed the cmotorsports 236-245 cam?
- Dirty vs. new 02's and N20
- Anyone have pictures of their hidden setup?
- Can't decide on a couple nitrous components help me out
- are thier any nozzle kits out thier
- MSD Window Switch Install?
- whats the back of a electric nitrous guage look like??
- nitrous on my 502 ramjet
- NX Maf System VS NOS TB System
- Will this survive a 200 shot?
- Nitrous Question
- Spray and a problem
- anyone have pics of direct port NX kit installed?
- customized my 5177 kit
- What should AIR/FUEL ratio be??
- Pragram the TPS on Zex box
- question about remote bottle valve openers
- leak off filter, and bad msd pill question?
- Sealant on connections?
- Fpss
- progressive controller???
- Who here had "this" hidden system?
- dry nitrous jet sizing
- New to N20 NX vs. Nitrous Works/Wet vs. Dry
- Tuning for more power
- basic nitrous questions
- Nitrous Cheater Kit off Ebay...
- Where to place the nozzle?
- LT1 Fogger: I cant mount the Solinoids right off the Dist. Block....Is this ok?
- NX Dual Stage $680 SHIPPED
- NOS question
- Wiring for a Mallory 685 box?
- Wiring MSD Window Switch
- questions on very small shot of nitrous 93
- Timing
- tnt wet kit
- dual stage dry kit using wet foger nozzle
- So what fuel pump do I need with my dry kit?
- Do I Need A New Fuel Pump With The NOS Dry Kit?
- Cleaning nitrous filter
- timing retard box ?
- Quick nitrous questions...
- straight 95 octane or mix 50/50 100 octance with regular 93 octane?
- WOW, 100shot dry and my bolt on LT1=FUN FUN
- need nitrous parts
- N20
- Installed 5177, FPSS leaking bad, help!!!
- If the car is misfiring and I spray=bad??
- Air fuel ratio gauges worth it?
- Lean condition with my LT1 dry kit... Please help...
- Hows this setup sound?
- Just Bought N20
- Nitrous spray bar plate
- bottle mounting question
- Saw a curious nitrous kit. ?'s
- 100 shot on stock motor?
- Trick flow heads and nitrous
- Whats different between wet/dry shot?
- solenoid life/failure
- Who runs 3.73/Auto/26" tires?
- Is this motor "built" to take it?
- OK to leave bottle on???
- curious bout nos
- Need help with Direct Port
- Carbed N2O timing question
- Spraying my 383
- NX150 Shot
- Plumbing a dedicated fuel system...
- Gota question?Please help
- Has anyone ever heard this before?
- Wiring window switch
- Why do LT1 Dry kits come with fuel pumps?
- Grenatelli MAF with dry shot, anyone do this??
- LT1 wet kit
- Pure Oxygen
- ALL the safety items.
- TNT purge solenoids
- Nitrous Feed Line Size to HorsePower Rating
- Window Switch Wire, where does it GO???
- Window switch with a.......
- Will my dry 125 shot require FP too high for stock injectors to handle?
- Fuel cell options
- looking for a GOOD bottle warmer (mine sucks)
- Dyno tune or go for it?
- What nozzels to get, and where
- mounting NX wet kit solenoids on a BMR STB........will it work?
- When to get nitrous
- How is HP shot measured?
- Twin Nozzels and Aluminium Intake Elbow
- Can I run n20, if so how much?
- Purging air
- NX Flowing Fuel Pressure (gemini quad)
- bottler warmer
- Solenoid piston replacement
- What "nitrous" piston?
- Mount solenoids in cowl?
- Which NOS kit to buy??
- just got the basic nx efi kit what else do I need?
- n2o gauge on bottle valve?
- Does anyone know what plug gap??
- nos guage location
- Nitrous
- Fogger on lt-4 intake
- Should I buy this kit?
- just bought nx maf
- 75 shot
- New To Gas Need Advice!!
- 111LSA and N2O?
- How much can I spray through a NOS fogger nozzle?
- Is this a decent bottle bracket that I made??
- help ... holley and nitrous plate
- need help with N20 gauge
- 230/242 vs. 236/245
- Finally got the dyno results with the TNT kit
- NOSzles?
- NOS remote bottle opener survey
- Need nitrous install do's and don'ts
- Purge Kit
- wet vs dry?
- Need help shooting on a 236-242 110 cam
- What gear ratio is best with Nitrous & 6spd...
- where does everyone keep their bottle?
- Spraying 200+ HP before the TB
- Dyno run today (advice needed)
- 5176 50hp jets?
- Is just an AFPR enough to run 100shot (dry)?
- What is the LT1's stock fuel pumps max flow??
- Where/How much?
- Setting up MSD Window Switch
- anyone with a remote bottle opener, question
- Would you be interested in something that automatically opened/closed your bottle?
- Is N20 worth it????
- Two Bottle Pics???
- What gauges are best used for nitrous?
- Cheap Zex......
- Speed density w/nitrous ?'s
- purge in the hood
- wire 2 bottles together?
- Bottle Mounting ??'s
- Where are your switches?
- abuse on engine
- NX Part?
- Pix of selenoids mounted on LT1?
- dry shot w/o upping fuel pressure?
- Which NGK spark plugs do I get?
- solenoid sizing for fogger setup?
- [quote]It is highly recommended that you install non-projected nose style spark plugs
- Anyone have pics of their purge valve?
- How many 1/4 mile runs on 1 bottle?
- How hard is it to install a complete n2o system?
- NX (Nitrous Express) Kit What's good price?
- 3.4L with NOS questions!!!
- LT1 w/ Nos
- RPM for spraying
- How much is too much nitrous for me?
- question about purge kit
- Post pics of your Stand alone for your Direct Port
- pill selection
- how much nitrous on a 396
- Nitrous Newb, need opinions
- 355 parts for a big shot of N2O...
- Nitrous Plans???
- TNT f1 Kit?
- is bad to run plugs that might be too cold?
- N20 track times
- Plugs?
- dry fogger
- direct port guys, question about jet size
- Dual Stage Pics
- please explain to me>>
- What gear with N2O
- Is this basic kit good?
- Header Plugs and Nitrous
- 396 stroker with n20
- colder than TR-6 ???
- Best nitrous kit
- Nitrous
- Nitrous Switches...
- should i get nitrous?
- timing tricker
- what to do to bump up to a 175 shot???
- cam?
- Searching for 5.9*'s Is Juice still the way, I need help
- Activation question....
- My Motor + N20 question
- pulling timeing?
- Going to Dual Stage
- Need help with fuel plumbing
- Nitrous Guys
- Activation switches
- Direct Port Nozzle Placement for LT1: Wont it effect fuel flow? Where did you put em
- Is a window switch necessary with an auto trans?
- Where/how are you mounting your TNT Solenoids?
- Compucar LT1 plate kit?
- Is this a good kit
- What dosage, not an LT1
- how much juice?
- All you Direct Port LT1 Guys: What is your Jet sizings?
- Which NX kit would you choose???
