Where to place the nozzle?
Old Mar 10, 2004 | 06:47 AM
BAD97SS's Avatar
Question Where to place the nozzle?
I've been runing the nozzle after mass air, But with my new setup it is hard to keep it in this location. Can you run it in front of the mass air or is this a no no. I would like to keep it the way I had it because it worked perfect, but can't keep it there. Any help would be great. Thanks John
BTW: I have nos 5176 dry kit
Old Mar 10, 2004 | 12:09 PM
juiced_lt1's Avatar
If this kit is set up to run AFTER the maf, it will screw up the calibration if you spray in front of the maf because the maf will be reading the air flow all wrong and your a/f ratio will get ***ked.
Old Mar 10, 2004 | 12:53 PM
t-trimz28's Avatar
Re: Where to place the nozzle?
Uhh....if it's a dry kit you need to run it before the mass air meter. That is how the pcm compensates for fuel.
Old Mar 10, 2004 | 11:20 PM
JSK333's Avatar
If you have the 5176 dry kit, it adds fuel by bumping up the fuel pressure, so don't place the nozzle before the MAFS.
An easy place to put it is in place of the IAT sensor. Then relocate that to your air filter intake somewhere.
That's where I have my NX nozzle--it fits very snugly there.
Old Mar 11, 2004 | 04:11 AM
97SS0594's Avatar
im runnin mine at my elbow.
Stephen68
Oct 16, 2015 03:50 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
