Time to set the record....250+ through a stock shortblock
Ok the fogger is complete with the seperate nitrous enrichment fuel cell and pump.
What is the timing I should bump back with
200
250
300
Also I am running a 2 step colder plug right now. Will that be enough?
I just changed the oil with some 20w50 Royal Purple race oil.
Gas will be 100 in the tank and 116 in the cell, everything sound good here?
I am going to start off with the 200 so I can compare numbers to the 200 shot I was doing through my home made dual nozzle kit. Then it will be bumped to 250, if I dont like what I see shes getting the 300!!!
For those that dont know, I have a COMPLETELY STOCK SHORTBLOCK. I love pushing the limits.
200
250
300
IMO it won't handle too much using a single fogger setup. Do you have anything else done to the motor, head work, cam, bolt ons? On my heads/cam lt1 with a single stage 150shot i almost hit 600ft lb tq to the rear wheels.
I would do a dual stage setup and seperate the stages with about 500rpms. I'm sure a stock short block will easily take a 250shot and maybe even a 300shot...
What kind of fuel pump are you running?
I sprayed 200 through a 2 bit dual nozzle kit I made and at one point was spraying about 170 through a Dry shot, I dont think I will have any problems with this.
Its a Heads, Nitrous cam and every other bolt on possible. I am at this point thinking about a progressiver controller, but I am undecided.
Originally posted by mtxpert
Won't be setting a record with a 250 shot.
280 shot already being done on an Impala.....
The Cherry Bomb under new ownership
Mike
Mike
http://impalassforum.com/noncgi/ulti...=001144#000000
http://impalassforum.com/noncgi/ulti...=001192#000000
Here's your info...
Mike
Here's your info...
Mike
That means 300 baby
