leak off filter, and bad msd pill question?
i have a small leak where the fitting goes into the nitrous filter...tried to tighten it down more, but it wont go...can i just fill around the fitting with teflon paste? it looks like there was paste on the part of the fitting that is in the filter anyway...
2nd question - is it possible for a 3000 MSD window switch pill to go bad or something? I tried a 3000 and it didnt work, but the 3200 did. Anyone have experience with this? the 3000 also was loose in the window switch, while the 3200 fit snug.
thanks
thanks
Is it a TNT kit? They had some defective filters that would leak. I think they are good about replacing them. I don't see any reason you can't use teflon paste. If it is not a flare fitting it definately needs paste.
Dustin
Dustin
Deadbolt24
Jan 19, 2015 01:29 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
. I would take the fitting off and make sure that it is not cracked.
