wet vs dry?
Old Feb 17, 2004 | 12:47 AM
godofdragons's Avatar
wet vs dry?
look, i cant find anything on the difference so unless someone explains it to me i will forever be a newbie on the subject.
what is the difference between wet and dry nitrous?
Old Feb 17, 2004 | 04:54 AM
RacinLT1's Avatar
dry injects only nitrous through the nozzle and uses the injectors to add fuel.
wet injects fuel and nitrous at the nozzle.b
Old Feb 17, 2004 | 07:56 AM
mtxpert's Avatar
There's only one more thing you need to know about dry, it uses the injectors to add the fuel by raising the fuel pressure only when the nitrous is engaged.
My 175 shot took the fuel pressure to just under 90 PSI as compared to stock 43 PSI at WOT.
Just a heads up, get injectors (GM's lock around 80 PSI - CLOSED) that will handle the increased PSI. SVO's lock OPEN, big difference in keeping your motor alive.
Mike
Old Feb 18, 2004 | 06:44 PM
thanks for the info, it seems so obvious now
Old Feb 18, 2004 | 07:39 PM
rskrause's Avatar
Moderator
There are other ways a dry system can work. For example, if you have an aftermarket PCM (FAST, Accel, Electromotive, etc.) you can use it to control the nitrous and to handle thefuel delivery.
Rich Krause
Old Feb 18, 2004 | 07:47 PM
mtxpert's Avatar
You are correct Rich, I forgot to mention that.
Still gonna need new injectors, just larger due to the increased HP requirements.
Of course most people won't spend $1500+ to do a dry system that way.
Mike
Old Feb 18, 2004 | 07:54 PM
rskrause's Avatar
Moderator
Still gonna need new injectors, just larger due to the increased HP requiredments.
Mike
Truth.
I prefer "wet" due to the ease/precision of tuning and the easy adjustability.
Rich
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
