Window switch with a.......
Old Feb 27, 2004 | 11:50 PM
smacz28's Avatar
Im wondering if you can use a window switch with a ZEX kit since it is self comtained....I am interested in trying to run one of their kits but I am afraid of not using a window switch on my high mileage motor.
Shawn
Old Feb 28, 2004 | 02:23 PM
BILLJ's Avatar
Yes you can. What you have to do is have it trip a relay that breaks the TPS line to the box or the ground line to the box. I've seen the TPS setup so I know that works and I have called ZEX about window switch use and they said break the ground wire. I question that though because I don't know if you will loose your TPS setting memory when you break the ground line.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
