Activation switches
If you are asking about the activation switch ASSEMBLY, the kind you'll see here http://www.jimmy-jams.com/activationswitch.htm
NX doesn't have custom assemblies......they only have a generic bracket that's a flat piece of metal you have to figure out how to bend it to make it work.
*R
*R
Here is my NX panel installed in my ashtray. Note that it is not designed to go in there, it requires careful modification via a dremel to get it to be perfect,
http://www.eden.rutgers.edu/~bhawalka/switch4.jpg
So, all this will tell you is yes this panel will work as shown, but you need to use common sense to get it installed. IMO, this is the most clean way for a nitrous setup.
.http://www.eden.rutgers.edu/~bhawalka/switch4.jpg
Rich Krause
jackpawt883
Sep 10, 2015 08:53 PM
