LT1 Fogger: I cant mount the Solinoids right off the Dist. Block....Is this ok?
There is absolutely no room to have the solinoids mounted right off the block which sits above the intake. It looks like I will hve to run 4 about 24inch maybe less 4an lines to the pass side for more space. Is this ok that I have a gap in the solinoids to the block? I know the initial hit will take a lil longer because of the gap but anything else I should worry about?
I could run either the fuel pair or the Nitrous pair on top, but not both. If I did the Fuel pair direct and then a short line for the Nitrous Solinoids about 6 inches long would this be ok?
Jul 4, 2005 05:00 PM
