Can't decide on a couple nitrous components help me out
Old Mar 15, 2004 | 10:06 PM
94irocz's Avatar
First off I have a 15lb nx bottle should I keep it or switch to a 10lb bottle my friend has? If I keep the 15 pounder where should I put it?
Secondly which set of activation switches should I get? The nx switches or the jimmyjam set up?
Any help or incite you can give me to help me make up my mind would be greatly appreciated.
Joe
Old Mar 15, 2004 | 11:52 PM
NXz28's Avatar
I'd keep the 15lb bottle and put it where the spare tire is. You can put all the switches inside the ashtray...
Old Mar 16, 2004 | 08:28 AM
94irocz's Avatar
Which switchs would be a better choice though. I know both will fit in the ashtray.
And I've read on here that the 15lb bottle will fit in the spare tire well but you can't get the best bottle angle by putting it back there.
Joe
Old Mar 16, 2004 | 10:18 PM
Zippity'Z's Avatar
If you want a customized fit and a flashier look for your switches to go into the ashtray then jimmy jam's is the way to go. The NX switches are generic to just go wherever you can make them fit. Jimmy Jam's also has the custom bolt-on WOT switches also. :-)
*R
Z28Freak86
Apr 30, 2024 05:37 PM
camaroguy50613
May 27, 2016 09:00 AM
bandit383lt4
Dec 21, 2014 09:12 PM
