Tapping the TB
Old Mar 21, 2004 | 10:40 PM
neil350's Avatar
Tapping the TB
I saw holley has an LT1 TB that was tapped for gas, If I bought a used LS1 TNT kit off the board could I essiantly take the nozzles off the ring and tap them in to my stock TB?
Old Mar 22, 2004 | 12:38 PM
dkeers's Avatar
You can definately make the kit work.
I think you would be better off tapping the nozzles into the intake elbow. I think it is possible to tap them in the TB but you have to be very careful that they won't interfere with the blades opening and closing. I don't see any benifit to putting them in the TB over the intake elbow.
Also, make sure you check the jetting. I don't think the LS1 jets are the same as the LT1 jets (because they run at different fuel pressures). I don't have the card with me from my old TNT kit so I don't know for sure.
Dustin
Old Mar 22, 2004 | 01:34 PM
speedmiser's Avatar
Neil, If you dont want to tap the TB or air box/boot, I've got a Compucar plate with 100, and 150 pills you can use.
surreybrad
Sep 29, 2015 09:00 PM
FryedClutch
Sep 1, 2015 08:24 AM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
BigWil
Mar 29, 2015 12:24 PM
Built350camaro
3rd Gen / L98 Engine Tech
Aug 20, 2002 11:54 AM
