Pragram the TPS on Zex box
Old Mar 13, 2004 | 12:36 PM
nutts 96 ws6's Avatar
OK well I have a few questions about the zex box, I bought it used and im having trouble with it. i have the zex box hooked up to a relay which im sure is wrong on the relay, im confused what to hook up where on the relay. I have two constant powers to the relay, the power to the zex box to the relay and a wire that goes to the rmp window switch. Its worked before but for some reason i think i have somthing backwords. Does anyone know how to hook this up the right way like this? Also when its hooked up right I need to relearn the TPS with the little button on the side of the box. Is there any specific way to learn it. Also I know that I have to bypass the window switch will the car is on but not running. I know this sounds really confusing but I hope someone can make some sense of it. Thanks.
Old Mar 14, 2004 | 01:17 AM
lt1form's Avatar
Its been 2 years, so I going from memory.
1.MAKE SHURE BOTTLE IS DICONECTED OR VALVE OFF!!!!
Turn on key, and push accell pedal to floor a few times, have friend look at the light on the zex box.
I think it stops blinking or turns a different color, when it learns the wot tps voltage when you push the pedal down a few times, I think you have to push the pedal down slow.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
truecontr3
Oct 11, 2015 09:30 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
