MSD Window Switch Install?
I have a MSD Window Switch that I want to install on my 99TA. Does it have to be modified for a LS1 or will it work without any modifications. What is the easiest way to hook it up? If I install the Window Switch, do I still have to install a Wide Open Throttle Switch? Any help will be greatly appreciated.
Thanks,
Curt
Thanks,
Curt
Even with a window switch you will still need a WOT switch or something to control when you want to start spraying nitrous. The window switch simply controls in between what rpm range you want to spray, for ex: 3,500 - 5,000...
Got it. Where do I hook the wire for the MSD Window Switch? It says to hook it to the TACH or the - side of the coil. The instructions are generic (not LS1 specific). Thanks for the help.
Curt
Curt
Jan 23, 2015 01:13 PM
