Hows this setup sound?
Old Mar 5, 2004 | 03:24 PM
Serene's Avatar
I have a 383 and am going to be running a dual stage 200 shot on it. Most likely 100/100 but I might do 125/75 either way I know im spraying 200 total
I have a 4AN line coming up front from the bottle into a y, with each leg of the Y going to a stage of nitrous. I'm fairly sure the 4AN here will support the power.
The part I am concerned about is the fuel side. I will have the same setup on the fuel side. Take a line off the schrader valve and the Y it to each fuel solenoid. Will the 4AN line here support 200hp?
Lastly, what fuel pump should I get to support a 383 +200nitrous? I'm putting a new rear end in so I will can have easy access to the tank. Is an intake better than an external? Pros/cons?
Old Mar 7, 2004 | 10:41 AM
Serene's Avatar
ttt
Old Mar 7, 2004 | 12:46 PM
RacinLT1's Avatar
i'd say at least a walbro 255 intank and the racetronix wiring harness should do it.
as far as the fuel line,yes it'll work. i would suggest 100/100 or 72/125,smaller shot will help traction.
Old Mar 7, 2004 | 04:01 PM
Serene's Avatar
Alright cool!
Does anyone have a jet size vs horsepower chart? I have a bunch of various jets, but nothing to tell what hp.
brandboZ28
Jan 31, 2003 06:19 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
ls1z01
Jul 30, 2002 02:39 PM
BergerSS435
Jun 26, 2002 11:06 PM
