Spray and a problem
Old Mar 14, 2004 | 11:52 PM
1994CamaroZ28's Avatar
Spray and a problem
was at the track spraying the nitrous
Well changed out all the spark plugs both back cylinders had melted plugs.
new plugs in it has one hell of a poppin sound like a manifold gasket, seems to run fine past like 1500 but at idle it shakes and runs rough.
im thinking about just ordering a set of headers, but i dont think that will fix the problem would the exhaust leak cause that type of probelm?
or a valve etc?
Old Mar 15, 2004 | 08:14 AM
12Second3rdgen's Avatar
Sounds almost like a fuel distribution problem what nitrous kit are you running? What fuel are you running? How much retard? How much nitrous?
Old Mar 16, 2004 | 12:24 AM
CRCDUDE's Avatar
UNIT broke.. Do a compression and or leakdown test. If you melted plugs theres a good chance you knocked a hole in the piston or broke some rings:
Old Mar 16, 2004 | 05:41 AM
Nostang 96z's Avatar
I agree had the same thing happen with my stock engine. Popped and the car shut off started up idle really rough but smoothed out above 2000rpms. # 7 piston had lots of chunks missing from it.
Matt
warmeck
Mar 22, 2015 06:43 PM
Fatdog2
Feb 13, 2015 08:19 PM
tds1213
Nov 27, 2014 12:55 PM
T/A lt1
Oct 10, 2002 03:14 PM
