How big can I go?
Old Mar 26, 2004 | 02:55 PM
Sweetred95ta's Avatar
How big can I go?
I have sprayed 150 before, but I am building a motor that can withstand a bigger shot. What besides the fuel pump do I have to do? timing?
Thanks,
Benji
Old Mar 26, 2004 | 04:02 PM
slomarao's Avatar
your question is sort of open ended. When building a nitrous motor you have to think about off the bottle. The more things you do to work with the nitrous the better results you will have with it. It is going to be a trade off with n/a because of the heads, cam, etc that will the best with the bottle will not be the best off of it. If you only looking to have the motor handle a 200 shot then buy some forged pistons and good bolts and many some bearings. Tell us more of your intentions with the car and better advice will be gave to you.
Old Mar 26, 2004 | 04:21 PM
No, trust me, it can handle it. The motor is about built, completely forged bottom end, custom grind cam ect. Just want to know what else besides the fuel pump I need to mess with to spray a bigger shot.
Benji
Old Mar 27, 2004 | 11:11 PM
Kain's Avatar
You basically have to balance how big of a shot you want to run, with how much timing you want, and what octane fuel you're going to run.
Old Mar 28, 2004 | 01:04 AM
Well, is there anything I can do about the timing? Can I use a timing retard box or something? Is the timing the only thing besides fuel delivery and octane I have to worry about?
Thanks,
Benji
Old Mar 28, 2004 | 01:47 AM
slomarao's Avatar
get a msd box to pull some timing and run high octane gas. If your bottom end is forged then I wouldn't be afraid of a 250 shot with some timing pulled, 100+ octane, and a good intank pump. A progressive controller would help the motor slowly take the hit of nitrous rather than a direct 250 shot. Look them up and read about them. you can control them with a palm pilot. The NX one is dope.
Old Mar 28, 2004 | 04:00 PM
How many timing degrees would I have to retard to spray 250?
Thanks,
Benji
bunker
Jan 30, 2016 08:09 PM
Sep 18, 2015 03:46 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
Boss002
Jul 9, 2015 03:33 PM
